ID sensor borad mpc2051
  • gneebore
    • Feb 2010
    • 555
    Need the part number for the id sensor boasrd on an MPC 2051. Have looked all over the place for a parts manual, but am kind of restricted on paying for the manual. I have cleaned the sensors and the mounting plate under the transfer belt. The machine worked for about ten pages and then started throwing the cs400 error again. It can be cleared by cycling the main power switch. But returns after one page has been printed.
    • 37481
    • copier tech
      • 8143
      Re: ID sensor borad mpc2051
      D0746100 - DENSITY SENSOR
      Here's the parts manual
      MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 50GB now!
      • Service@PRT
        • Oct 2016
        • 181
        may ask for the part number of id sensor cover for this machine? thank you.
        Every day of life is a learning process...
        Just make sure you are open in all aspects of comments.
        • TonerMunkeh
          Professional Moron
          • 3865
          The black plastic one? D0396324.
          Hit it.
          • Polarbear
            • Feb 2012
            • 1070
            Another thing that causes sc400 is there is a metal plate that is part of the ITB that is directly above the ITB sensor assembly. This plate has 3 rectangular holes in it that match up with the id sensors. Over time toner collects on top of this plate and as the machine works the toner falls through the holes onto the sensors.
            Remove the ITB assembly (first remove the itb cleaning unit on the left side of the machine, then remove the toner waste bottle, switch the black drum transport lever to the up position, then drop the right door to about level so that the ITB can be pulled out without touching the right door).
            Once the ITB is removed, stand it on its rear side and remove the left (now top) handle (2 screws) and lift the handle off. Slide the plate upwards and away from the belt. You will no doubt see a purple mass of toner there. Clean said plate and installation is the reverse of the above.
            Press the GREEN button!!
