Ricoh MPC4500 Magenta toner covering drum
  • The Copier Man
    • Aug 2025
    The message on the op panel says "add magenta toner" The toner is full, open and spinning. Inspection of the drum revealed the drum is covered in toner. The drum and dev have about 10,000. Any suggestions?
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh MPC4500 Magenta toner covering drum
    Dev unit might have gone bang. Do you have another one to swap in as a test? Eliminates boards and things.
    Hit it.
    • maikel safwt
      • Nov 2014
      • 58
      I think the toner in not compatible if wright change the toner and print some paper with a magenta background
      • Iowatech
        Not a service manager
        • 3930
        If the drum is covered with toner it could be that the toner is wrong.
        So you might need to replace the developer or the developer unit when you get compatible toner.
        It also could be that the magenta drum unit was damaged. If it is possible, you might try a color drum unit from a working machine, or one you replaced that wasn't totally worn out and see what happens (no need to buy a new drum if this is wrong).
          • 37535
          If it thinks that it needs to add toner because of a bad TD sensor, it most likely has drastically over toned the magenta development unit. Replace the DEV UNIT.
          • bob marley
            • Jan 2012
            • 1339
            I agree with Iowatech and it seems to be a wrong toner problem
            Live for yourself and you will live in vain. Live for others, and you will live again
            • fbkhan3
              • May 2012
              • 421
              Sometimes it happens when Charge terminal in PCDU is not making proper contact with the rear side terminal or is covered with Toner.
              Bad ID sensor or covered with toner.
              Regard's
              • mikadonovan
                • May 2008
                • 2931
                Nine times out of ten if the toner bottle is full and the "add toner" condition still exists, the toner pump for that color needs replaced.
                NEVER ASSUME ANYTHING
                • Amin
                  • Nov 2009
                  • 4
                  You have to replace the toner pump. some times it can be the sensor back the machine.
                  • duane@pbbsinc.com
                    • Mar 2011
                    • 77
                    I agree with the post talking about the charge terminal with exception to it being the terminal I have had the charge roller unit pop out of its tabs and cause a no charge condition which in return will dust the drum with magenta toner on a write to black image machine.
                    Either way a type 811dn printer drum assy with some tweeking of the connector and front cover will fix this issue.
                    Or swap with a working magenta drum assy as a test if charge roller assy looks normal.
                    Hope this helped.
