The message on the op panel says "add magenta toner" The toner is full, open and spinning. Inspection of the drum revealed the drum is covered in toner. The drum and dev have about 10,000. Any suggestions?
Ricoh MPC4500 Magenta toner covering drum
Tags: None
Re: Ricoh MPC4500 Magenta toner covering drum
Dev unit might have gone bang. Do you have another one to swap in as a test? Eliminates boards and things.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it. -
I think the toner in not compatible if wright change the toner and print some paper with a magenta backgroundComment
So you might need to replace the developer or the developer unit when you get compatible toner.
It also could be that the magenta drum unit was damaged. If it is possible, you might try a color drum unit from a working machine, or one you replaced that wasn't totally worn out and see what happens (no need to buy a new drum if this is wrong).Comment
If the drum is covered with toner it could be that the toner is wrong.
It also could be that the magenta drum unit was damaged. If it is possible, you might try a color drum unit from a working machine, or one you replaced that wasn't totally worn out and see what happens (no need to buy a new drum if this is wrong).Live for yourself and you will live in vain. Live for others, and you will live againComment
Nine times out of ten if the toner bottle is full and the "add toner" condition still exists, the toner pump for that color needs replaced.NEVER ASSUME ANYTHINGComment
Either way a type 811dn printer drum assy with some tweeking of the connector and front cover will fix this issue.
Or swap with a working magenta drum assy as a test if charge roller assy looks normal.
Hope this helped.Comment
