SRAM has been formatted due to problem with SRAM message
  • fshead
    • 2376
    hi
    i have a mpc2550 copier i just bought and have to deliver 1 hour away.
    i thought i cleared it fax service mode >ram clear> factory mode.
    it went away but i think when i unplugged it it came back.
    does this have to do wth the 3volt lithium batteries on the MBU brd?am i clearing this right?
    thnx
  • Bantams
    • Jun 2012
    • 603
    Re: SRAM has been formatted due to problem with SRAM message
    Only ever seen that come up when fitting a fax option power off/on usually fixes it.
    • Elmo
      • Feb 2010
      • 541
      check the fax option there is a jumper for the back up battery make sure its set to on
      also make sure the small piggyback board is properly connected
      I Used To Live To Fix Things Now i Fix Things To Live
        • 37532
        thnx
        [ATTACH=CONFIG]29076[/ATTACH]
        If the jumper is in the "ON" position, the battery could be bad. The jumper turns the battery on/off.
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          You did a fax ram clear then rebooted and got the sram has been formatted prompt, this would be expected. Next you should access the address book in user tools, exit and reboot, the message should clear after that...... My experience with this and my 2 cents worth.................
          Mystic Crystal Revelations
          • Polarbear
            • Feb 2012
            • 1070
            +1
            Press the GREEN button!!
            • fshead
              • 2376
              thnx all.
              it seems all is ok as long as i dont unplug copier..
              i will buy a few 3v wth pigtails and try to repair.
              anyone have a cheap source for 3v lithiums wth wires soldered..
              i cldnt get my loose ones to take a solder.
              i have had this problem before but didnt need the fax option so i pulled it .
              the battery was dead.
                • 37532
                I did a search on Yahoo. Came up with this amongst others. Panasonic VL2020/HFN Lithium Rechargeable Battery -Solder Tabs (1+/1-)
                • fshead
                  • 2376
                  thnx
                  i have a high end adjustable solder station but could not get any wires to connect to bare battery
                  so what you found looks like a perfect fit..
                  i thought the batteries were only for speed dial number and such.
                  • cadillac2
                    • Oct 2015
                    • 42
                    if the fax board is out of the machine or the machine stays unplugged the MBU battery will die. Looks like Ricoh then wants you to buy a new MBU board.
                    I soldered in a battery holder for a CR2450 3v Li battery - ebay has these holders and batteries. The spacing on the pins lined up with the holes on the board. worked like a charm - and next time changing the battery will be a breeze
