MP4000 upto MP5000
  • fuwei2422
    • Nov 2014
    • 49
    MP4000 upto MP5000
    MP4000 upto MP5000 the control and BICU ,I alreay complet, but the BICU ,I do not khnow whear IC control the speed , want to have also me ,thanks a lot
  • skynetto
    • Sep 2012
    • 257
    Re: MP4000 upto MP5000
    It cost less to buy a hacked cronometer for the customer wich steals ten seconds x minute.
    • anothertech
      • 1766
      I like the hacked cronometer idea, it's got to be easier than trying to speed up one of these Ricohs. Now if you really want to speed up the MP4000, replace the IO pcb, the SBU pcb and the contoller, format the HDD, you need to clear NAVRAM on the controller, then load the MP5000 frimware. Good luck, be patience, it's not easy.
        • 37447
        You also need a valid serial number as if the speed portion of the serial number does not match, it will throw a code and just might blow one of those replaced boards. Oh, by the way, you will have to replace the NVRAM, possibly at least one motor, possibly the laser unit and the polygon motor. These are items that on many of the 35/45 ppm models were different. To be sure, get yours parts catalog and go through it item by item. If a reference number on the explosion page shows two different numbers on the number then list, then that part is different.
        And if you are wanting to change from a MP 4000B basic model with B/W scanning to a MP 5000 with color scanning, you need to replace everything except the frame and covers.
        • sandmanmac
          • 3981
          Since November!
          http://www.copytechnet.com/forums/ri...to-mp5000.html
            • 37447
            Originally posted by sandmanmac
            Same person. Also has wanted to make a 1035 into a 1045 and a 6001 into an 8001. I am thinking about adding him to my ignore list.
            • Iowatech
              Not a service manager
              • 3930
              Also, whether you convert the machine or not, if you are not willing to maintain it properly afterwards it will become an engine of sadness for both you and your customer.
              At least that's what I've seen, for what it is worth.
              • anothertech
                • 1766
                I just think it's funny, so I give them false hope!
                • fuwei2422
                  • Nov 2014
                  • 49
                  MP4000 and MP5000 diffent is control BICU ,now the control i alwasy ok,but the bicu I don know where is th IC SN s control speed ,
                  • impetus73
                    • Mar 2012
                    • 75
                    How to I change a SPC250 into a PRO5100s ? I really need to do that :-D
