Ricoh 3800c Error SC543
  • bobg
    Machine stopped said change Fuser Unit, replaced fuser Unit and now I am getting the Error SC543, and machine will not boot up.
  • JustManuals
    • Jan 2006
    • 9838
    I have a file on Ricoh error codes posted on one of my sites at:
    Manuals 4 You - Free
    Stop by, make yourself at home, buy something
    Paul@justmanuals.com
    • CANCOUNTRY TECH
      • Aug 2008
      • 114
      sound like fuser lamps are overheating.You probably need a PSU or BCU i would put my multimerter on the PSU wher the lamps plugg into if theres no 240 volts its the PSU if there is its the BCU.
      Good luck
      • Baphomet
        Copier Technician
        • Aug 2008
        • 293
        Did you remember to reset SP5-810 to 1?
        • mlad
          SC680 -lanier 2138
          could someone tell me what sc680 is? the end user could be wrong but this is what she told me. I am not at the location of the machine atm to verify code.
          manuals 4 u - this code was not on your error code list -
          • iMind
            Vacuum Cleaning Expert
            • Mar 2008
            • 1116
            SC 680 could have something to do with the toner bottles, this is a memory chip error or bad conection between bottle and holder.
            sigpicWe can all Win, but at the end we all loose. Save the greyhound
            • oswaldo160
              • 69
              hi
              It said the manual:
              SC-543
              Heating roller fusing lamp overheat
              Toner cartridge memory chip loose connection
              Memory chip problem
              Memory chip cable wiring problem
              • mlad
                SC680 -lanier 2138
                Sorry bob for the mixing of posts... didnt mean to jump on and confuse.
                thanks for the help guy;s... unit all fixed now.. was toner issue
