ricoh gear
  • Users Tech
    • Nov 2013
    • 85
    ricoh gear
    hi guys,
    need help about this ricoh aficio 3045 gear. i looked for this in the ricoh aficio 1045/3045/mp4500 parts catalog but can't find it. this is a 31teeth gear found in the inner part of the machine and this turns the gear of the developing unit but is not part of the developing unit.
    10984635_10204062791029611_5785232298375684145_n.jpg17096_10204062734068187_7727413463950044696_n.jpg11219150_10204062734508198_2109643367642855166_n.jpg
    please help. i need the part # for this gear.
    thank you.
  • totoro
    • 568
    Re: ricoh gear
    I can't find just that gear, but there is a developer drive unit B213 1136 that might have your gear on it. That is the only thing I can find. I hope that helps.
    Totoro
    • logrady2331
      • Feb 2011
      • 301
      Re: ricoh gear
      My educated guess is this gear is part of the development drive unit (B2131136) and that's why you can't find a part number for it. I looked through my manual also and couldn't find it.
      • bob marley
        • Jan 2012
        • 1339
        Re: ricoh gear
        that is correct
        Live for yourself and you will live in vain. Live for others, and you will live again
          • 37628
          Re: ricoh gear
          Parts catalog for the 1035/1045 has a part number of B0041136 for the same assembly.
          • Users Tech
            • Nov 2013
            • 85
            Re: ricoh gear
            many thanks guys. quite expensive to replace this huh! it's only the gear that is broken but i have to replace the whole development drive unit. i need to replace more than 20 of this. i asked some machine shops to have this fabricated but not cheap too and not sure if the result will be a success. any idea where i can buy just the gear (if there's any)? just trying my luck.
              • 37628
              Re: ricoh gear
              Just a thought, 3D printer.
              • Users Tech
                • Nov 2013
                • 85
                Re: ricoh gear
                Brilliant idea! i forgot about this. many thanks!
                • Users Tech
                  • Nov 2013
                  • 85
                  Re: ricoh gear
                  how about a little more discussions about copier gears being made using 3d printers. has anyone actually printed a copier gear and installed it on a machine? does it work? can it last long? i talked to a 3d printing company and they said that i have to provide them with the 3d design of the gear which is impossible for me to get unless someone shares it because scanning the actual gear and have it printed will not work. any thoughts?
                  • yianni
                    • Jan 2013
                    • 42
                    Re: ricoh gear
                    It's this. Where do you live?
                    • yianni
                      • Jan 2013
                      • 42
                      Re: ricoh gear
                      Originally posted by Users Tech
                      h i talked to a 3d printing company and they said that i have to provide them with the 3d design of the gear which is impossible for me to get unless someone shares it because scanning the actual gear and have it printed will not work. any thoughts?
                      The difficult part of the use of 3d printers is to get the 3d design of the part you want to print. The design a 3d part is time consuming.
                      The better way for these purposes is to make a mold -to copy the part-. Not design it from scratch.
                      • Users Tech
                        • Nov 2013
                        • 85
                        Re: ricoh gear
                        you mean 3d scan it, edit and print? or how do you make a mold?
                          • 37628
                          Re: ricoh gear
                          Do some research. 3D printers do not require a mold.
                          • yianni
                            • Jan 2013
                            • 42
                            Re: ricoh gear
                            Not 3d scanner and printer. You take a good shaped gear, you make a mould (like this) and then you pure in the plastic material to make a new gear (simplified method here).
                            But, to copy a part is time consuming and it costs enough (of course much less than scanning the part).
                            I have the ability to supply you these gears. Please, tell me your location, are you in USA? Or send me PM or email.
                            • Users Tech
                              • Nov 2013
                              • 85
                              Re: ricoh gear
                              yup i need to do more research. thanks.
                              thanks a lot. the machine shop that i visited said that they can make this gear using a mold but like you said, it costs enough and time consuming because of the design in the middle of the gear.
                              mold vs 3d design
                              many thanks! more power.....
