ricoh 1013
  • akm
    • Sep 2012
    • 155
    [CQ] ricoh 1013
    Dear/Copytechnet
    i want your help to solve the problem with Ricoh Aficio 1013 that gives black lines although i changed the drum sep and cleaning blade
    i send a sample
  • Iowatech
    Not a service manager
    • 3930
    Re: ricoh 1013
    Looks like the drum is bad based on the repeating dot pattern to the left of the lines on your example.
      • 37477
      Re: ricoh 1013
      Did you replace or at least clean the charge roller? A dirty or worm charge roller will leave a pattern like that.
      • sandmanmac
        • 3981
        Re: ricoh 1013
        Originally posted by akm
        Dear/Copytechnet
        i send a sample
        You apparently rebuilt this unit with generic parts, rather than installing a new one? Even though they were never meant to be rebuilt.
        As stated above, looks to me like a contaminated PCR, damaged drum and/or a defective blade.
        The print quality defects were obviously different than this before you rebuilt the unit right?
        • akm
          • Sep 2012
          • 155
          Re: ricoh 1013
          thanks for your answer i will try to clean the charge roller ,check and will feedback the result
          thanks
          akm
