Cover off the front, 2 screws. Joint holding the bearing, 2 screws. Unplug connector. Remove the e-clip and the bushing at the rear. Done. Did you even try to take it apart? It only took me 5 minutes to figure this out my first time. BTW, when you say you need it immediately, it sounds a little demanding which results in little to no response most of the time. If your looking for immediate, buy a service manual. Seems like you're going to need one anyways.
