RICOH AFICIO C 830
  • techmayor92
    • May 2015
    • 18
    RICOH AFICIO C 830
    PLEASE DID ANYONE KNOW TO SEPARATE
    DRUM FROM DEVELOPER TANK ON RICOH C830 PLEASE I NEED ANSWER IMMEDIATELY
    • THANKS
  • Polarbear
    • Feb 2012
    • 1070
    Re: RICOH AFICIO C 830
    • THANKS
    Is that model SPC830DN?
    Press the GREEN button!!
    • techmayor92
      • May 2015
      • 18
      does anyone know how to separate it
      • mikadonovan
        • May 2008
        • 2931
        Cover off the front, 2 screws. Joint holding the bearing, 2 screws. Unplug connector. Remove the e-clip and the bushing at the rear. Done. Did you even try to take it apart? It only took me 5 minutes to figure this out my first time. BTW, when you say you need it immediately, it sounds a little demanding which results in little to no response most of the time. If your looking for immediate, buy a service manual. Seems like you're going to need one anyways.
        NEVER ASSUME ANYTHING
        • techmayor92
          • May 2015
          • 18
          Thanks a lot it work for me
