mp6000 startup
  • vargue
    • Oct 2011
    • 404
    [Dead] mp6000 startup
    hi fellas i'm very frusrated i have machine mp 6000 internal used .i make built up on it coast about 2.000 egp then turn on machine it's please wait.... and no response. then i clean rams and and take off hdd .then machine begin to start but give the same issue .i realized that up right controller 5 led ignite red. and input/out put two led green.and controller fan running . after that .i closed machine in my work shop .after one day i tried again.give the same result and worse controller fan not turn .and no resopnse from controller any help appriated. i take off hdd .and cleaned ram after sc672 and cassets bcp.red led ignite
  • slash
    • Apr 2015
    • 20
    Re: mp6000 startup
    I'm pretty sure it's controller. SM says - Controller board defective / Controller board installed incorrectly / Operation panel harness connection loose or incorrect, but my experience says controller.
    • banginbishop
      grumpy old git
      • Oct 2007
      • 894
      Re: mp6000 startup
      Also look at the PSU - had one doing it recently & the PSU was causing it. Controller was changed, dims swapped sc672 please wait etc.
      Incontinentia Buttocks
      • bob marley
        • Jan 2012
        • 1339
        Re: mp6000 startup
        had the same problem more than once and it was a defective controller
        Live for yourself and you will live in vain. Live for others, and you will live again
