Ricoh MP 5500-8000 Series, Quality Problem, Toner or Drum???
  • Codex
    • May 2008
    • 704
    #31
    Re: Ricoh MP 5500-8000 Series, Quality Problem, Toner or Drum???
    Originally posted by Vollegaaz
    The last 2 or 3 months i've seen a lot (+20 different machines) with that strange fuzzy/blurred image, after replacing the drum it disappears, but after a couple weeks it seems to come back...even more strange is that the problem occurs often and only during the morning, the first 100-200 prints of the day, so you should think its more like a humidity issue....but as mentioned, after replacing the drum the problem is gone for 3-4 or 5 weeks
    light copies is an issue that i see more and more on these machines, developer with only 100k has to be replaced and so on...
    I've heard there's a fuzz with bad toner in the field, but no official communication so far...
    Ricoh is not Volkswagen... They'll ever admit nothing.... We have 100+ machines with the same problem..... Ricoh knows it that something is wrong with the type 9002 toner...... They sent us developer for free last month...... What does this mean in your eyes?...... I guess they found the problem... And in the next stock of toner the problem disappears...... I'm sure its NOT an humidity issue..... The problem starts last year... Before everything worked... (type 6210 toner)
    Ricoh does make a tool for doing this. See the service manual for the Pro 907EX for how to use.
    A2949560 Paper Dust Cleaner - 5pcs/set
    Memento Audere Semper
    • NeoMatrix
      Senior Tech.
      • 3513
      #32
      In all honesty I can't say I'm aware of the issue. Different climate maybe ?
      Where possible I try an run a brush or small blade screwdriver under the doc blade during a normal PM.
      If it's the doc blade is causing the repeated issue, then make use of the problem to your advantage.
      Take advantage of the problem:
      Let the toner build up under the doc blade as it normally does, but now place a thin micron metal shim under the doc-blade and screw the doc-blade back down onto the shim. The shim will lift the height of the doc blade by microns, and the toner will build up to compensate for the extra gap ?
      It might get you an extra 50-100k of extra copies before issue returns. Which will get you to the next PM and you can then clean the doc blade.
      You can purchase 150x150mm(6"x6") sheets of harden shim steel at most hardware, bearing supplies or auto-parts shops. The harden steel shim package comes in various sizes 1mm down to 0.1 or there about. Cut off 6mm(1/4") small squares with Tin snips/shears and pack under the doc-blade for a test ????
      Try it on one machine first an see if it makes any difference. Try different shim thickness to find the right height.
      Just make your technicians aware of the extra gap when doing a PM.
      HTH
      • Codex
        • May 2008
        • 704
        #33
        HTH
        We did this on two machines for test, but the problem is still the same.......we have the same problem on Aficio 1060/2075.....it's not an MP issue......i repeat again and again, in our case the problem starts when Ricoh changed the toner from 6210 to type 9002...
        • Zeldaman
          • Mar 2011
          • 946
          #34
          Hi there!
          This tip from Ricoh is in german, but it may help.
          Greetings...
          • Codex
            • May 2008
            • 704
            #35
            • trc
              • Jan 2007
              • 95
              #36
              • Codex
                • May 2008
                • 704
                #37
                I'm sure it's the type 9002 toner....we sent the developer we changed to ricoh Netherlands... To analyze it..... No results till now... We never had this kind of problem with the type 6210 toner
                • Codex
                  • May 2008
                  • 704
                  #38
                  UPDATE:
                  two weeks ago Ricoh send us new Type 9002 toner with the advice "try this".......and surprise......the problem seems to disappear......machines that never made more then 20k copies without having blurred image or other quality related problems now make 150k and more without any problem.......so...if i'm not stupid the problem was the toner......of course nobody admits anything......i hope that after almost one year, angry customers, tons of developer this story finds an happy end......
                  • limo
                    • Jun 2008
                    • 103
                    #39
                    Do you see any difference in the new bottles from the problematic ones? Can you tell me the small numbers written in the good toner bottles i.e.4J4 323 03
                    Thanks in advance
                    • Codex
                      • May 2008
                      • 704
                      #40
                      Hello.. You mean the lot.numbers?....the problem disappeared..... After ricoh sent another toner stock........ We had the problem on different lot. Numbers..... I guess something went wrong in France....
                      • limo
                        • Jun 2008
                        • 103
                        #41
                        Yeap i mean the Lot no. Can you confirmed that on the new toners the Lot no starts with 5J4?
                        • Codex
                          • May 2008
                          • 704
                          #42
                          Yes! I'm on a customer right now... Three machines... All three lot n. 5j4....
                          • Codex
                            • May 2008
                            • 704
                            #43
                            Had you the same problem?
                            • limo
                              • Jun 2008
                              • 103
                              #44
                              Yes extactly the same.Up to now we were using the lot no 4j4 but nowwe receive bottles from lot no 5j4 . We have towait and see.
                              • Codex
                                • May 2008
                                • 704
                                #45
                                Ok.. Where are you from?..... I suggest not only to change toner.... But to clean the "toner box" on the development unit, so you can start with new toner...... And eventually change developer..... In some cases the developer is gone because of the faulty toner
