MPC4000
  • GeorgeBest
    • Jul 2009
    • 526
    MPC4000
    Hello,
    This machine has some troubles on color prints. Lot of distortion. (See atachments)
    normally, SP2111-003, mode c and mode a (2x) will solve the problem. SP2194-007 says good!
    However this time not (?!)
    Checked the transfer, cleaned the laser, even changed the polygoon motor.
    No results!
    anyone a clue here? (PCU ?, wich one?)
    hope someone can give me the right tip here, returns tomorrow
    thanks in advancd
  • GeorgeBest
    • Jul 2009
    • 526
    Re: MPC4000
    • Max
      • Oct 2011
      • 561
      Re: MPC4000
      Make sure that the belt is not damaged/worn on the edges and not rubbing on the drums as its going around. Music sensors nice and clean. run off a solid page c-y-m-k should be nice and even. If not then music sensors cant do colour registration/faulty. Check error log, possibly drum rotation sensor playing up.
      • anothertech
        • 1771
        Re: MPC4000
        If still a problem, I'b bet it's the ITB. assy. , replace that and the cleaning assy.
        • sandmanmac
          • 3983
          Re: MPC4000
          See Eric1968's reply to my post from over a year ago on an MP C3000. It solved my problem then, and a few more times since:
          http://www.copytechnet.com/forums/ri...tml#post400489
          • anothertech
            • 1771
            Re: MPC4000
            That right there looks like some good information, I'll print it and keep it with me, Thanks
