Ricoh mp 6001, no warm up, no display
  • kcsolomon
    • Jul 2025
    [Dead] Ricoh mp 6001, no warm up, no display
    Guys,
    Need help with this one, MP 6001, doesn't warm up and no display after I turned it on. first it caused by jam paper, after I removed the paper mis-feed, display prompt need to restart, 3 times same issue. after the 4th time when I turned it on, the main problem occurred.
    TIA!
    • 37513
    Re: Ricoh mp 6001, no warm up, no display
    If you can access WIM, check to see if it is displaying a service code.Probably SC 202. The polygon mirror will need to be displayed along with the BICU. There are a number of threads on this problem.
