How to chance serial numbers when changing network board on 830DN
  • harrishabitat
    • Jun 2015
    • 7
    I believe the network card on the our 830dn is bad, tried multiple cables and same problem with all of them. I swapped the boards out but I get a error that serial numbers don't match. How do I go about changing the serial numbers?
  • mikadonovan
    • May 2008
    • 2931
    Re: How to chance serial numbers when changing network board on 830DN
    You don't. Remove the NVRAM from the old controller and put it on the new one. Just a note, I looked at a 810DN where the network port is built in to the controller.
    NEVER ASSUME ANYTHING
    • TonerMunkeh
      Professional Moron
      • 3865
      Did you move the controller Nvram from the old board to the new one? What fault were you experiencing originally?
      Hit it.
      • harrishabitat
        • Jun 2015
        • 7
        Thanks for both of the responses... is the NVRAM just the regular ram in a PC? Or is the NVRAM something different?
        For some reason the 830dn is no longer showing up on the network and we've tried difference cords and everything and still experiencing the same issue so we assumed it meant the board needed to be replaced.
        • TonerMunkeh
          Professional Moron
          • 3865
          Follow the replacement and adjustment procedure in the service manual. Before you do though, print off a configuration page and post it on here will you? Board replacement is a bit drastic.
          Hit it.
          • harrishabitat
            • Jun 2015
            • 7
            Ok I have swapped out the board and now I am getting contectivity on our switch but not seeing it on the network map now. I know I have data through the line but for some reason I can't see the printer in the network. Here is the config page.Ricoh 830 Configuration Page.pdf
            • ZOOTECH
              Senior member of CRS
              • 3378
              Originally posted by harrishabitat
              Ok I have swapped out the board and now I am getting contectivity on our switch but not seeing it on the network map now. I know I have data through the line but for some reason I can't see the printer in the network. Here is the config page.[ATTACH]29375[/ATTACH]
              I don't see a gateway or sub-net mask address under IPV4 - won't you need those for a network connection?
              • harrishabitat
                • Jun 2015
                • 7
                We had an employee that thought he understood networking and he FUBAR'd our equipment. Is there a way to do a master reset on the networking or is there somewhere I can go to find the correct network settings? We are kinda new to the programming of these printers.
                • sandmanmac
                  • 3990
                  Please call a tech.....
                  With due respect....It's just a bit insulting that you would just start aimlessly swapping circuitry on a printer simply because it doesn't print, yet you don't even possess the knowledge to check that the proper network settings are done in the first place
                  Control board problems are almost always accompanied by Error messages, and SC codes when they are in fact the culprit
                  • anothertech
                    • 1771
                    [QUOTE=sandmanmac;474773]Please call a tech.....
                    With due respect....It's just a bit insulting that you think you would just start aimlessly swapping circuitry on a printer simply because it doesn't print, yet you don't even possess the knowledge to check that the proper network settings are done in the first place
                    Control board problems are almost always accompanied by Error messages, and SC codes when they are in fact the culprit[/QUOTE
                    I couldn't agree more, your in over your head, call a tech.
                      • 37628
                      Turn on DHCP in order to use the machine until you get a qualified MFP tech out there. Many IT personnel understand networking but do not know how to apply that information anything other than a computer or a HP printer.
                      • mikadonovan
                        • May 2008
                        • 2931
                        You are sunk hip deep into this. I should NEVER assume anything, BUT, if the printer worked ok before, I'll give you the fix. The network settings for the machine have to be programmed in and the procedure is WAY too long for me to step by step. I see that DHCP is turned off, and no static IP is set. 1.Try turning on DHCP, reboot and see what happens. If not, you will have to manually input the IP address. All of these instructions are here. Will it take a while? Yes. Will it save you money if it works? Yes. If it doesn't work, call a local tech. It would have cost you a minimum labor charge at my place of business and in 30 minutes you would have been back on line, not swappin' boards. Just saying. Here's the link to the to Ricoh manual downloads. If the link doesn't work, just Google Ricoh-Usa.
                        • mikadonovan
                          • May 2008
                          • 2931
                          You beat me to the draw by a couple minutes While I was typing, you were posting.
                          • TonerMunkeh
                            Professional Moron
                            • 3865
                            There's nothing wrong with the old controller board. IEEE802 authentication was active and it was locking the NIC out on the old board. Switch it off and all should be spiffing.
                            Hit it.
                            • mikadonovan
                              • May 2008
                              • 2931
                              Good Call, TM. I missed that on the config page.
