Ricoh MPc5000 sc565 are there any serv bulletins on this issue?
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    I am looking for information (prefereably Serv Bulletins, not Svc manual I already have that one ) for this error, SC565 (Ricoh MPc5000 )
    Thermal parts have been changed unsuccesfully.
    Machine with different issues all the time, as a matter of fact any service bulletin folder/collection for this model is welcomed.
    (also known as D027 D028 D029 or Apollon-C2a/b ), my mail is:
    rapidocument@gmail.com
    I have helped to other techs with documentation in the past
    please help me out this time.
    I can provide manuals for almost any brand in exchange, you tell me which and how many you want.
    No problem !
    Thanks !
    My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
    • 37538
    Re: Ricoh MPc5000 sc565 are there any serv bulletins on this issue?
    From Goose's Guide:
    SC 565 PR lamp full pwr >180 secs - A level code, reset with SP5-810
    SC 565 PR lamp full pwr >180 secs - replace PSU
    SC 565 PR lamp full pwr >180 secs - check thermistor with SP1-106, replace as needed
    SC 565 PR lamp full pwr >180 secs - Replace Fusing Unit
    If you do not have Goose's Guide download it from here http://www.copytechnet.com/forums/ri...oose%27s+guide
    • TonerMunkeh
      Professional Moron
      • 3865
      565 is usually the pressure roller stats being blown.
      Hit it.
      • llyyhh
        • Mar 2013
        • 9
        replace the fuser lamp.
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          No bulletins for this code but if you have to replace the fuser the Printer model is cheaper and fits with an easy modification.
          Part no:403119 SPC820dn
          • Gift
            • Mar 2011
            • 2459
            Good luck with that - IIRC this fuser does use an inductive heater.
            Does the fuser at leat get noticeable warmer until it hits the SC? If not, you might deal with a faulty IH coil unit or IH inverter board.
            I also managed to trigger the bi-metal fuse while cleaning the area - thought this was an infrared thermal sensor
            I was able to reset the fuse pulling the metal with some hot glue and a tiny screwdriver - totally legit methods^^
              • 37538
              Check continuity of the thermostat where it connects to the IH inverter board. If it reads open, Ricoh says to replace the entire IH coil assembly. As a temporary fix, by pass the thermostat at the connector.
