MPC 3003 SC899 / 819
  • Bantams
    • Jun 2012
    • 603
    I have a MPC3003 that was showing SC899 on arrival so I updated the firmware and switched it back on SC899 came on again even with network unplugged tried format the HDD and then it shows SC819 whilst trying to do the Format HDD ALL procedure Any Ideas other than a Dead Controller?
  • anothertech
    • 1768
    Re: MPC 3003 SC899 / 819
    Can you try to turn on the power with the front door open, maybe it won't code like that. Then get in to user tools and turn on user authentication, that may drop the offending job.
      • 37481
      Not all SC 899 are related to printing. When you update firmware be sure to update everything. Also be sure not to install SOP firmware unless you have a Smart Operation Panel. If you have a Smart Operation Panel do not install normal operation panel firmware. I do not find SC 819 listed for the MP C3003, but for most machines it is a fatal kernel error.
      • TonerMunkeh
        Professional Moron
        • 3865
        Java EXJS firmware can also cause stupid SC's like this, even if it's not being used.
        Hit it.
        • Polarbear
          • Feb 2012
          • 1070
          Hi.
          Does that machine have a fax unit onboard? I have had faulty fax units cause SC819 before. Remove all optional peripherals, like bridge units and fax units and start the machine in its most basic state, then start refitting and testing these one by one until it codes.
          Faulty printer memory on the controller can also cause SC819. Try removing, cleaning and reseating the memory. Also try known working memory (same type and capacity).
          Press the GREEN button!!
            • 37481
            Originally posted by Polarbear
            Hi.
            FAX is also one of the options that can cause SC 899. That is why i always update all firmware.
            • Bantams
              • Jun 2012
              • 603
              Sorry was the HDD seemed to have a undeletable job on it had to buy a caddy to format it in the end its fixed now
              • dawn
                • Mar 2011
                • 48
                New firmware might solve the issue- system/copy 1.26, Lcdc 1.10, websupport- 1.11
                • LANUN_81
                  • Jan 2017
                  • 12
                  yup sc 899 oocur whe you print from webpage...cancel all print job and restart the machine.suggest cust or user download first then prnt
                    • 37481
                    Or preview the page and print from the preview screen.
