Ricoh MP-1600 Can not add e-mail contacts on the Webb Monitor (do not see that opt
  • funtime@57
    • Jul 2025
    Does any body knows why , wen going to add e-mail or fax contacts thru the Ricoh Webb Monitor does not show this options . machine can only copy and print. Does have the SD memory cards on the side. Fax address on the bottom and scan on top.
  • nmfaxman
    • 1702
    Re: Ricoh MP-1600 Can not add e-mail contacts on the Webb Monitor (do not see that
    Both options have to be installed in the machine before you can access it.
    Check recycledparts.us.
    Great pricing with 30 day warranty.
    • cesaromero
      • Nov 2011
      • 6
      the Ricoh Webb Monitor does not show this options because you have the first copiers that have the first firmware, try update the firmware if you have it
      • rsyarcia
        Hair Straightener Tech
        • 711
        if you have the P/S kit installed, you have to check the location of the SD card maybe installed in wrong slot. Put it in slot 1
        Nobody is perfect..
        • mongo
          • Jul 2009
          • 55
          Did you log into the web monitor as a administrator. If not the address will not show on some of them I don't have a MP1600 to look at but if the machine has everything on it. I'll check that first. Mongo
