Mp 9000 possessed by the devil
  • Mocafer
    • Mar 2015
    • 23
    Please help !!!
    • 23008
    Re: Mp 9000 possessed by the devil
    Is there an interval that it repeats? =^..^=
    • nmfaxman
      • 1702
      Fuser pressure is not set.
      That is why you are getting threads of toner.
      Are both the pressure springs engaged?
      • Codex
        • May 2008
        • 704
        looks like developer dusting....did you vacuum the dev and pcu unit? is the cleaning unit set correctly?
        Memento Audere Semper
        • impetus73
          • Mar 2012
          • 75
          If it's possessed by the devil, then you need to install the "Exorcism SD card V2" in the lower SD card slot, and press "Start Exorcism" on the menu. :-D Then burn the card afterwards.
          • Mocafer
            • Mar 2015
            • 23
            • Mocafer
              • Mar 2015
              • 23
              • Mocafer
                • Mar 2015
                • 23
                • Mocafer
                  • Mar 2015
                  • 23
                  • Mocafer
                    • Mar 2015
                    • 23
                    Sandmanmac
                    I do not understand because you punished me with -10 to my reputation, I'm waiting for some spare bearings to finish repairing the machine, I live in a country where it is not easy to get spare parts, in fact I had to learn to design in SolidWorks to make parts replacement in 3d machines, be patient, next week I'll report how I was with this problem, I think between the pressure of the fuser and the ball bearing unit revealed this mystery, but I would like to repair this quick score that you put me, I'm just here to help in what little information and share it, it's not a game to me. I will share with you some pictures of the prints in 3d gears and other pieces I've designed, even a paddle roller does not come to replace the developer unit Aficio MP 7500 1075/2075.
                    I do not love you
                    • Mocafer
                      • Mar 2015
                      • 23
                      [ATTACH=CONFIG]29718[/ATTACH][ATTACH=CONFIG]29719[/ATTACH][ATTACH=CONFIG]29720[/ATTACH][ATTACH=CONFIG]29721[/ATTACH][ATTACH=CONFIG]29722[/ATTACH][ATTACH=CONFIG]29723[/ATTACH][ATTACH=CONFIG]29724[/ATTACH]i
                      • allan
                        RTFM!!
                        • 5462
                        SolidWorks is great use it all the time!
                        Whatever
