Paper tray showing empty when fully loaded
  • WP_CS
    • Jun 2015
    • 10
    [Jamming] Paper tray showing empty when fully loaded
    Getting this problem when the paper tray is fully loaded (or 3/4), the tray showing empty on the panel. If I reduce the quantity of paper (says about 250 sheets) then it will display on the panel as half-loaded.
    Model is Ricoh MP3350. Thanks.
    • 37487
    Re: Paper tray showing empty when fully loaded
    Check the paper out switch. Also check the paper size switch. I have seen the size switch in dusty environments think that the tray is not fully inserted and thus show the tray as being empty. A little vibration or change in the weight in the tray and it will change. I had one where it would show it had paper. As a sheet was feeding it would show paper out and then come back to having paper.
    • ponto700
      • 144
      also check this part if not cracked or broken... i already have this problem before and after change this part i fix my problem!
      • Gary Bowen
        Bowdog
        • Mar 2008
        • 250
        I think this is part of what slimslob is talking about. This little switch causes all kinds of problems and may be the source of your problem.
        • Debs1964
          • Oct 2010
          • 1693
          That's what my money would be on
          There are 10 types of people in this world, those who understand binary maths and those who don't
            • 37487
            That switch will cause auto size detect to detect the wrong width. I.e. letter LEF will be detected as Half Letter SEF. As a result, the wrong timing will be set for the paper lift and feed jams will occur. I have encountered the problem even with machine with the mylar installed when the bracket was bent.
            This is the switch I was mentioning. Dirty contacts will cause it to think that the paper tray is not fully inserted.
            • WP_CS
              • Jun 2015
              • 10
              Thanks guys. I will give it a try when visiting client side.
