Ricoh MP C4500
  • Reed
    • Feb 2011
    • 261
    Ricoh MP C4500
    The color registration is off on this Ricoh MP C4500. I can go into the maintenance menu after pressing user tools/counter button and perform the color calibration page but when I try to perform the color registration the machine runs for a few minutes then stops and and says it is unable to perform adjustment. I have attached a sample of the color calibration page and a sample of a color copy. The machine also has the same problem when executing a print job. Any help would be appreciated. Thanks in advance.
  • skynetto
    • Sep 2012
    • 257
    Re: Ricoh MP C4500
    Laser calibration is off. Issues can be different: developer low, id sensor dirty, toner low and settings set to calibration off when toner low ecc
    • logrady2331
      • Feb 2011
      • 301
      Re: Ricoh MP C4500
      I would do a forced toner refresh and then re-run registration form user mode. Your cyan is light and the registration will be off, especially if the cyan is light and the machine can't make the patch. My bet is once you do forced toner refresh the registration will be right. Of course the basic things should be done like cleaning, id sensors clean, good t-belt, etc.
      • nmfaxman
        • 1702
        Re: Ricoh MP C4500
        There is a forced color registration method in service mode.
        Can't remember the code off the top of my head, but start with 3 first then work up to 1.
        Then do the all the calibrations in user tools.
        • sandmanmac
          • 3990
          Re: Ricoh MP C4500
          Forced line position adjustment:
          SP3211-3 (rough)
          then
          SP3211-1 (fine) - do this one twice
            • 37644
            Re: Ricoh MP C4500
            SP3211-3 (rough)
            then
            Clean the image density sensor first.
            • bob marley
              • Jan 2012
              • 1339
              Re: Ricoh MP C4500
              Can't remember the code off the top of my head, but start with 3.
              The forced color registration [Forced Line Position Adj.] start with 2not 3 [2-111]
              SP 2-111-003 Executes once.
              SP 2-111-002 Executes once
              SP 2-111-001 Executes twice.
              Live for yourself and you will live in vain. Live for others, and you will live again
              • sandmanmac
                • 3990
                Re: Ricoh MP C4500
                OOPS! My bad! You would be correct.
                I seem to have a touch of lysdexia (dyslexia) tonight.
                I'm blaming NM for planting the thought of SP3xxx in my head
                (joking of course!)
                  • 37644
                  Re: Ricoh MP C4500
                  A lot of people say to do SP 2111-1 twice after doing SP 2111-3. Sp 2111-1 actually executes fines adjustment, SP 2111-2, twice. The actual directions in the service manual says to do SP 2111-3 and the do SP 2111-1, or do SP 2111-3 and then do SP 2111-2 twice. You can also do Auot Color Alignment in User Tools.
                  SP 3011-1 is Manual Process Control and should be done after cleaning or replacing the ID sensor.
                  • Debs1964
                    • Oct 2010
                    • 1693
                    Re: Ricoh MP C4500
                    Clean the ID sensors, clean the sensor located on the underside of the front, right hand corner of the ITB unit
                    Run SP 2-111-003
                    Run SP 2-111-001 twice
                    Then execute colour registration in user tools
                    That's what I do anyway
                    There are 10 types of people in this world, those who understand binary maths and those who don't
                    • Zaxxon
                      • 608
                      Re: Ricoh MP C4500
                      If nothing of the above works, give the customers a box of these:
                      Please start you post with brand, model, problem.
                      • jfbar1
                        • Oct 2008
                        • 53
                        Re: Ricoh MP C4500
                        Sounds like "someone" did an engine clear (BIG NO NO). Best way to resolve this is to (hopefully) get the birth certificate behind the label inside the front door. Input ALL magnification ratio and laser motor values manually, then do the forced line adjustments and finally, the color registration in user tools.
                        • Reed
                          • Feb 2011
                          • 261
                          Re: Ricoh MP C4500
                          Thanks for all the input. I performed
                          sp 2-111-03 (once)
                          2-111-01 (twice)
                          Then color registration twice for good measure . It fixed the problem
