The 1022 doesn't have waste toner collection, though it does have toner recycle. Also, the 1022 doesn't have separate developer, it uses a complete PCU replacement. If you mean that developer is getting drawn onto the drum and cleaned off in the cleaning / recycling area, then the drum is probably shot and you need a new PCU.
if i'm not mistaken the machine uses drum type 1027 (pcu assembly), if dev goes inside the cleaning unit, either the chrg volt is too high, dev bias adj., bias grnd(if dv&dr was replaced sep) or incompatible dr&dv might be the cause.
