MP301 cover open message on a new machine
  • Streamlined
    • Aug 2025
    We have a brand new machine out of the box with a cover open message (right cover). What's the best/easy way to remove the door switch? Or has anyone experienced this issue and has found a solution.
  • sandmanmac
    • 3981
    Re: MP301 cover open message on a new machine
    Here's what I do when I purchase something new and it doesn't work 'right out of the box'... I put it right 'back in the box' and return it for a credit, or a new one.
    I'm curious why that isn't what you do?
    • Iowatech
      Not a service manager
      • 3930
      Rather than remove the safety interlock switch, it might be more productive to look for a broken interlock actuator on the right hand cover.
      Pictures would be useful so that we can help you with that as we can't see your machine. Thanks.
      • jonhiker
        • 661
        Also, removing the interlock switch would create other problems. If it's brand new, get a replacement
        • bob marley
          • Jan 2012
          • 1339
          Originally posted by jonhiker
          get a replacement
          That is the most suitable solution
          Live for yourself and you will live in vain. Live for others, and you will live again
          • trc
            • Jan 2007
            • 95
            Sometimes is a PCU disengaged.....
            • ninerfanatic492000
              • Aug 2013
              • 14
              push switch on main chassis(right below scanner base on right side/door side) has been damaged or literally shoved into interior cavity b/c of packing or blunt force. not terrible to replace but make sure scanner is ok, once anything in there is broken or eschew it will never work 100% correctly again. switch is usually all black plastic or outer casing is black and actuator part of switch is white plastic. We've had a few arrive with this type of damage. We've RMA's some and repaired some when in a hurry to get them out to customer
              • RandyW
                • Jan 2013
                • 213
                Had one also with the push switch damaged.
                We acquired a used one from 1 of those used equipment wholesalers- 3 altogether- and 1 had a cover open message.
                Ended up being a push switch that is on the right side just about at the top of the machine. It's about 1.5" maybe to the right
                of the latch if you look at it with the right side cover open. Switch was sort of damaged so I put the pieces of it back together and
                has been fine since. The white plastic actuator part of it was loose.
                Unfortunately I didn't discover this until replacing the microswithches inside the cover first. Not really the best set up for getting access to that area.
