Ricoh MPC2503 Yellow Background on copies and prints.
  • Vioksrall
    • Sep 2010
    • 84
    Guys I need your advice. Our customer has MPC2503 machine that constantly having yellow background on prints and copies. Although we repeatedly replaced PCDU-Yellow but still keeps coming back. But if print the calibration sheet, it's ok. I have tested the Transfer Unit but also ok. Does anyone has experience like this? Thanks in advance.
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Ricoh MPC2503 Yellow Background on copies and prints.
    Did you reset the PCDU counter for yellow? If you don't, the voltages will be off and can cause coloured backgrounds. (This model does not auto detect a new PCDU)
    • Vioksrall
      • Sep 2010
      • 84
      Thank you for your reply. We always reset the PCDU counter everytime we replace them. All the firmwares are updated..
      • petermuylle
        • Jul 2015
        • 18
        Is it an even background, or an assortment of dots with a pattern to it?
        (in case of the pattern, this is normal)
        • Vioksrall
          • Sep 2010
          • 84
          Yes sir, it is an even background covering the whole page. It's like you're printing using a yellow colored paper.
          • rsyarcia
            Hair Straightener Tech
            • 711
            long ago I encountered this with mpc3500 but only on copying. there is a setting on copying mode that you can set the background to lighter. you can use it to isolate your problem.
            Nobody is perfect..
              • 37557
              Have you checked the machine side contact for the charge roller? This sounds like the yellow drum is not being properly charged.
              • Zaxxon
                • 608
                Don't know this model, but on metis there is a grounding plate on the pcu's if these are missing it can cause all kinds of obstructions on the print.
                Please start you post with brand, model, problem.
                  • 37557
                  The MP C2503 is part of the Metis line. He has already replaced the entire PCDU which is the PCU and DVU as a complete unit.
                  • petermuylle
                    • Jul 2015
                    • 18
                    Did you happen to build over the part in red (that is the ground plate) if you replaced pcu and developerbox as 2 units; you need to salvage this part from the old pcu.
                    I dont know if it is included in the complete unit.
                    • Vioksrall
                      • Sep 2010
                      • 84
                      [ATTACH=CONFIG]29857[/ATTACH]Did you happen to build over the part in red (that is the ground plate) if you replaced pcu and developerbox as 2 units; you need to salvage this part from the old pcu.I dont know if it is included in the complete unit.
                      We are fully aware about that issue coz it already happened to us. Without that "ground plate", the problem will be light copies/prints. I personally double checked physically the drum unit and transfer belt unit and installed new HV board but still not ok. We had changed 3 PCDUs (yellow) already because of this problem.
                        • 37557
                        Let me restate my previous post as you have not yet answered it. "Have you checked the machine side contact for the charge roller? This sounds like the yellow drum is not being properly charged."
                        • Vioksrall
                          • Sep 2010
                          • 84
                          I think you have a point, let me update you tomorrow. Thanks a lot.
                          • mabawser
                            Tech
                            • Sep 2009
                            • 121
                            can I just ask what you mean by "build over the part in red". I have a call which has been escalated to me as the prints have gone light and I think drum and dev assemblies have been replaced. I assume you mean you can rebuild the unit without the red plate?
                            • rthonpm
                              • Aug 2007
                              • 2859
                              Just the opposite. You need to use the highlighted part from the old machine.
                              Sent from my BlackBerry using the Android app.
