Ricoh MPC4500 Scan to MAC OS10.10
  • tufbnme
    • 493
    Can anyone tell me in simple terms how to (or if it is even possible) set up scan to folder on a MAC os10.10?
  • nmfaxman
    • 1702
    Re: Ricoh MPC4500 Scan to MAC OS10.10
    No. Scan to folder uses SMB for transfer which is a Windows protocol.
    Mac does not have SMB. Install FTP on the mac and scan that way, or email.
    • rthonpm
      • Aug 2007
      • 2852
      Apple and all Unix systems support SMB, through the use of Samba. Starting with OS X 10.7 SMB is the native file sharing format in OS X since it provides more stable performance than Apple's old AFP protocol.
      Here's a link to the easiest method to setting up a share folder. The instructions are for 10.7, but the overall process hasn't changed.
      How to Share Folders from Mac OS X with Windows 7 & Windows 8 PCs
        • 37444
        You may need to update NCS firmware. Don't have time right now to look up exact firmware you will need, but with as old as the C4500 is it will probably require special/custom firmware.
        • tufbnme
          • 493
          Can you tell me how to set up FTP? Never done it, don't know where to start.
          • copyaction
            • Oct 2007
            • 985
            I'm scanning to 10.10.3 with an MP161, no firmware update needed.
              • 37444
              If you have been keeping your MP 161 up to date on firmware then it already has NIB firmware v6.19 released 7/10/13.
              The MP C4500 was no longer a production model at the time OS 10.7 was released and therefore there is no standard firmware for the C4500. There is a Special/Custom firmware available from TSRC or rfg-esource, B222_NCS_v5.20_LRC0355 dated 2/7/13.
              • copyaction
                • Oct 2007
                • 985
                Just checked has NIB v6.11
                • anothertech
                  • 1766
                  What type of scanning are you doing? FTP scanning, or pull?
                  it's not SMB is it?
                    • 37444
                    You can do SMB with older firmware if you know how to disable SMB security on the MAC.
                    • copyaction
                      • Oct 2007
                      • 985
                      it's not SMB is it?
                      it is SMB
