Ricoh MP-C2500 SC-681
  • ksp
    • Oct 2013
    • 22
    [Error Code] Ricoh MP-C2500 SC-681
    Been working on this mp-c2500 that wont show that there is a toner cartridge in it and wont add toner even if I do a force toner. Then I get this sc-681 code RFID problem. So I replaced the RFID board with a known good one and it wont go away. I have tried 3 different toners still same problem. I have replaced toner pump and dv unit twice also the toner sensor and nozzle unit. I had to change machine out so customer is up and running but need to still fix this problem if for no other reason then its killing me not to know. Please help if you have had this problem . Thanx Kevin
  • nmfaxman
    • 1702
    Re: Ricoh MP-C2500 SC-681
    Turn off RFID in service mode, then force feed.
    It will eliminate the RFID as a problem.
    Also, only use OEM toner on color boxes, or you are just creating weird problems.
    • kannuki2
      • Feb 2012
      • 398
      what is the sub code SC681- ?
        • 37538
        From Goose's Guide:
        SC 681 RFID Comm error - replace RFID board # B2385050
        SC 681 RFID Comm error - replace toner cartridge for effected color
        SC 681 RFID Comm error - 01= black, 02=Magenta, 03=Cyan, 04=Yellow
        SC 681 RFID Comm error - replace BICU to IOB harness # B2385304
        SC 681 RFID Comm error - replace IOB to RFID harness # B2385308
        SC 681 RFID Comm error - check/reseat CN 232 on IOB
        SC 681 RFIC Comm Error - replace Controller and BICU as a set
        Since you have tried the RFID board, try the cables next.
        • Pixtech Frameworks
          • May 2020
          • 238
          "How do I turn off RFID in service mode"
            since this thread is over 5 years old...
            please start a new thread..
            with:
            model #
            what is exactly the problem
            using 3rd party toner
            what have you tried
            • mikadonovan
              • May 2008
              • 2931
              Don't know, maybe he was referring to disabling toner end detection, SP 3045.
              NEVER ASSUME ANYTHING
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                You can't turn it off if faulty you need to replace
                Regards Mark
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  Here's some information
                  Regards Mark
