Ricoh Pro C5100
  • fatfingers73
    • Feb 2013
    • 219
    [CQ] Ricoh Pro C5100
    Afternoon all,
    Recently PM'd two of these and they're having print quality issues.
    They're picking up old images from the paper transfer unit.
    I'm guessing this unit isn't moving away from the transfer belt when it should be.
    All Ricoh help desk said was to make sure the media catalogue was up to date (which it is).
    Any advice would be appreciated.
    Cheers.
  • petermuylle
    • Jul 2015
    • 18
    Re: Ricoh Pro C5100
    Is there an inteval between these ghost images? (every x cm)
    • fatfingers73
      • Feb 2013
      • 219
      Re: Ricoh Pro C5100
      No they're pretty constant. These are the only two charis I have. The new ptr's got dirty very quickly.
      Somethings not right?
      Thanks.
      • petermuylle
        • Jul 2015
        • 18
        Re: Ricoh Pro C5100
        could you include an example?
        • fatfingers73
          • Feb 2013
          • 219
          Re: Ricoh Pro C5100
          There you go.
          Thank you.
          • jfbar1
            • 53
            Re: Ricoh Pro C5100
            Its NOT a PTR issue. Definitely a paper type mismatch in the paper settings. If you run thicker paper under Paper 2 weight, It will NOT fuse properly. Also in the "advanced settings" (if enabled) under user tools, there is a couple of settings for fusing temp that need to be checked. The PTR does get pretty discolored during normal use but rarely has anything to do with actual PQ. If there was an issue with PTR lift, you would get an SC.
            Sorry I don't have easy access to documentation anymore (Left Ricoh in May after 27 + years), but hopefully will give you some direction to go. Good Luck
            • fatfingers73
              • Feb 2013
              • 219
              Re: Ricoh Pro C5100
              That's great. Thanks for your help.
              Will update ASAP.
              • Imprestik
                • Aug 2012
                • 296
                Re: Ricoh Pro C5100
                There is a technical bulletin for this issue
                Update your media library to the latest version (which is version 11) it will get rid of the problem completely
                This is a known issue up to the media library version 9, it has been sorted from version 10 onwards
                • fatfingers73
                  • Feb 2013
                  • 219
                  Re: Ricoh Pro C5100
                  Mines on 12. Just seen a 16 for EU so I'll give that a go.
                  Thanks.
                  • Timmytronic
                    • Oct 2010
                    • 249
                    Re: Ricoh Pro C5100
                    Hi. Where do you check what version of the media library you have?. I have a couple of these machines but have only just got them so no problems yet. Is the update if required through Sd as normal?
                    Thanks. Tim.
