To all who have RICOH MPC 5000 doc, whe need help to solve a code error SC712 and the yellow toner problem we have put a new and it always say yellow catridge is empty. all our thanks for sending the doc.
Ricoh MPC 5000
Re: Ricoh MPC 5000
Google does exist
2: Replace yellow toner pump -
Re: Ricoh MPC 5000
Thank you for answering, the problem of the yellow toner is ok we have resolved it. For the code it's SC772 so i think it'is the finisher problem but the copier work well. So we have another problem, We want to configure the printer on windows xp sp3 32bit we have not the driver not again on the web site ricoh. If you can send us the doc technique and the driver. THANK YOU.Comment
Re: Ricoh MPC 5000
Re: Ricoh MPC 5000
Finisher jogger motor error
The jogger fences move out of the home position but the HP sensor
output does not change within the specified number of pulses.
The 1st failure issues an original jam message, and the 2nd failure
721 B issues this SC code.
Jogger HP sensor disconnected, defective
Jogger motor disconnected, defective
Jogger motor overloaded due to obstruction
Finisher main board and jogger motor
yellow toner problem - replace yellow toner pump ... Video: https://www.youtube.com/watch?v=uFwscuzJmpM
good luck
CopierMaps: Copier Dealer Locator | Copier Lease Guide | CopierMaps.com
