Ricoh MPC 5000
  • bomberi
    • 107
    Ricoh MPC 5000
    To all who have RICOH MPC 5000 doc, whe need help to solve a code error SC712 and the yellow toner problem we have put a new and it always say yellow catridge is empty. all our thanks for sending the doc.
  • sandmanmac
    • 3981
    Re: Ricoh MPC 5000
    1: SC712 doesn't exist so that makes giving advice very tricky. You probably mean SC721, but I'm not here to guess. Perhaps provide a little backgound on what you've done to resolve it?
    Google does exist
    2: Replace yellow toner pump
      • 37495
      Re: Ricoh MPC 5000
      Try changing SP 3045, Toner End Detect, to 1. If the machine then functions properly, you have either a bad toner cartridge or a bad RFID board.
      • bomberi
        • 107
        Re: Ricoh MPC 5000
        Thank you for answering, the problem of the yellow toner is ok we have resolved it. For the code it's SC772 so i think it'is the finisher problem but the copier work well. So we have another problem, We want to configure the printer on windows xp sp3 32bit we have not the driver not again on the web site ricoh. If you can send us the doc technique and the driver. THANK YOU.
          • 37495
          Re: Ricoh MPC 5000
          Try using the Vista or Windows 7 (32) driver. Most of Ricoh's 32 bit drivers for a given model are the same and so are 64 bit drivers.
          • he7060
            • Jul 2015
            • 14
            Re: Ricoh MPC 5000
            Ricoh mpc5000 - are you sure you have error code sc712 ??? maybe you have sc 721
            Finisher jogger motor error
            The jogger fences move out of the home position but the HP sensor
            output does not change within the specified number of pulses.
            The 1st failure issues an original jam message, and the 2nd failure
            721 B issues this SC code.
            Jogger HP sensor disconnected, defective
            Jogger motor disconnected, defective
            Jogger motor overloaded due to obstruction
            Finisher main board and jogger motor
            yellow toner problem - replace yellow toner pump ... Video: https://www.youtube.com/watch?v=uFwscuzJmpM
            good luck
            CopierMaps: Copier Dealer Locator | Copier Lease Guide | CopierMaps.com
