Ricoh Aficio MP8001
  • Reed
    • Feb 2011
    • 258
    Ricoh Aficio MP8001
    When using the ADF it slightly rips the leading edge of the paper where it passes between the ADF Feed belt and the separation roller. I have replaced the Feed Belt, Separation roller, Feed belt pulley, lubricated the ADF feed assembly. These have helped a little but it still rips the lead edge. Thanks in advance..
  • allan
    RTFM!!
    • 5462
    Re: Ricoh Aficio MP8001
    Does any thing seem to be bent?
    Whatever
    • Reed
      • Feb 2011
      • 258
      Everything appears to look good. The customer has 7502 in another room and I have even swapped out feed assemblies. The machine still puts a slight tear on the lead edge. Which makes me think it has to do with the lower frame unit. but just not sure
      • mbolduc
        • Jun 2015
        • 53
        Have you tried the torque limiter.....the white hub that the separation roller attaches too?
        • Reed
          • Feb 2011
          • 258
          I replaced it about 6 months ago. I wouldn't have thought it would be bad. But they are a title company so they scan A LOT! I'll try replacing it again.
          • MIKON
            • Jul 2015
            • 188
            Check the scan housing P/N D4123111.I have seen the rear anchor point crack .
