Ricoh 161 Duplex jams
  • Creedmoor
    • Aug 2025
    I have a 161 that jams when duplexing I have cleaned the one way bearing and that seems to take care of it for 3-4 weeks then they call back about duplex jamming. They havent complained about single sided jams. I get mainly Jam code 60, 210,211. of course it doesnt jam while Im there, any thoughts would be greatly apreciated.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh 161 Duplex jams
    I think you pretty much hit the nail on the head. I tend to replace the one way and shaft as a pair.
    Hit it.
    • nmfaxman
      • 1702
      Rough up the shaft where the bearing rides.
      The bearing tends to polish the shaft to the point that it slips.
      I use a scotch pad back and forth, so it looks dull.
      • logrady2331
        • Feb 2011
        • 301
        Agree a hundred percent with nmfaxman. It does NO GOOD to clean the one way and NOT rough up the shaft it rides on.
        • JonManchester
          Technician / Shop Manager
          • Aug 2013
          • 103
          I only clean the one way if I don't have a replacement on me. They are real cheap to replace and will usually prevent a recall. Like the previous comments roughing the shaft is a good idea.
          Live for something or die for nothing.
          • Zeldaman
            • Mar 2011
            • 946
            Hi there!
            Had the same issue, changed roller & gear - NG. After cleaning & lubricating the duplex-drive (espacily the part at the arrow) the duplex-jams were history.
            Greetings...
            • Polarbear
              • Feb 2012
              • 1070
              Originally posted by Zeldaman
              Hi there!
              Greetings...
              This little drive gear gets overlooked far to often and causes major headaches with duplex jams! Check this as standard these days when troubleshooting duplex jamming.
              Press the GREEN button!!
              • Creedmoor
                Thanks everyone for the help, I appreciate it. and Zeldaman thanks for posting the pic it was very helpful
