Pop up user code to print on MPC5001
  • kayjaig
    • 144
    [Misc] Pop up user code to print on MPC5001
    Hello all,
    Working on MPC5001
    How do i setup or active the pop up user code or job code to print for these. ( to separated from different projects)
    Please advice. Thanks.
  • Moza
    • 232
    Re: Pop up user code to print on MPC5001
    Originally posted by kayjaig
    Hello all,
    Working on MPC5001
    if you are talking about user codes for printing there is no pop up available unless you customise the print driver. If you are using the PCL 6 driver the code needs entering in job setup
    • Debs1964
      • Oct 2010
      • 1693
      As Moza says, the only way to get a pop up window for user codes is to use the print driver editor, you must delete all previous print drivers prior to customising and installing the edited driver
      There are 10 types of people in this world, those who understand binary maths and those who don't
      • tonnerboy
        • May 2011
        • 212
        You have a new tool that replaced the printer driver editor that is Printer Driver Packager NX.
        This is a wonderful tool when you understand it. You can use it for editing and deploying drivers.
        Remember as already said. You need to delete all previous drivers. You can not have both in the same PC.
        • Debs1964
          • Oct 2010
          • 1693
          I've only used it once, it took me 4 hours to work it out!! Problem is, that was months ago, I can't remember how to do it now, the print driver editor was so simple, even I could work it out
          • kayjaig
            • 144
            Driver download from Ricoh website, after unzipped. I don't see any printer .inf file available for editing. do you know where they are hidden from. Thanks.
              • 37529
              You have to use either Print Driver Editor or Printer Driver Packager NX. PDE is no longer available from Ricoh but you can search the internet. In fact it might be an attachment to another thread. After you have edited the unzipped driver, just install in as an additional printer and do not let Windows automatically select anything for you. When prompted if you want to use existing driver or install new do not use existing. The edited features will not be there.
              • gear13z
                • Sep 2011
                • 68
                you can use PDR or printer driver editor if you use the ricoh universal printer driver, some PCL driver dont work on this editor.
                .....with all it shams, drudgery, and broken dreams, it is still a beautiful world.....
                  • 37529
                  PDE is intended for use with PCL6 drivers to include the Universal Printer Driver for PCL, which in my opinion is a major road block on a busy network. PDE will not work with PCL5 or PS3.
                  • techsass
                    • Dec 2010
                    • 248
                    Find the ".RCF" file & open it with either Wordpad or Notepad.
                    Add the line in RED below and save it.
                    <?xml version="1.0" encoding="utf-8"?>
                    <rcf version="1.0">
                    <popupbeforeprint type="usercode"/>
                    </rcf>
                    Last edited by techsass; 07-24-2015, 11:40 PM. Reason: Copy & Paste messed up spacing.
                      • 37529
                      <rcf version="1.0">
                      </rcf>
                      The .RCF file will only exist if you have customized a print driver.
                      • redneckstylin
                        • Sep 2011
                        • 173
                        yes ricoh nx you have to install machine into it than install driver than do configuration of driver than add config driver into printer on ricoh nx
