Smart Operation Panel service/installation guide
  • RICOTECH
    Field Tech
    • Mar 2013
    • 13
    Giday all,
    After now winging my way through three installations with the new SOP, I think it's time to find a service manual.
    We've been given a number of installation documents on how to install the SOP and set the SP codes.
    Wifi direct from IOS and Android both work but all of this has been set up without a true Ricoh user manual.
    if anyone has any information that they think will help me (and others) please feel free to share.
    because at this stage there doesn't seem to be a great deal in the way of service manuals out there.
    many thanks.
    RICOTECH
    • 37555
    Re: Smart Operation Panel service/installation guide
    Even with the service manual, I would suggest calling tech support for help. The sequence in the manual is unclear and not exactly correct unless they have updated it since the first SOP I installed.
    • teebee1234
      • Jul 2008
      • 1670
      Here are links to video nuggets and install pdf's that may help....
      https://youtu.be/6RDJcr5v8MM (SOP install)
      https://youtu.be/KnE8wx_dIhU (Smart Connector NFC install)
      https://youtu.be/-7b5q1fYeTc (Smart Connector promotional video)
      https://youtu.be/wK5WeuhboEk (Smart Connector training video)
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        Another thing about the SOP install is to make sure the machine is unplugged from the power outlet, before connecting the wire/usb harness's...........
        Mystic Crystal Revelations
          • 37555
          Unplug and then press the power button until the power LED goes off so that all the capacitors discharge. I would advise against setting Smart Connect until the machine is on the customers network. It will save having to clear the settings when you do get to the customer.
          • DRichard
            • May 2008
            • 482
            "Enjoy every sandwich."
            -- Warren Zevon
              • 37555
              This procedure as shown in the service manual is not correct. I had called tech support prior to installing my first one and was told to update to the latest NOP firmware first. The SP settings should then be changed. The SOP firmware should be installed only after the SOP has been installed, preferably at the first power up. They also said to fully discharge the power supply immediately prior to attaching the SOP, after turning off unplug the power cord and then hold power button, the main power LED should flash on /off. Do not plug the power cord back in until ready to power on.
              • hashmi
                • Jul 2021
                • 1
                where i can find sop without access of tsrc
                • GIUBOSS
                  • 1437
                  Hi, you should start a new thread...
