Interrup Copy function for Ricoh MP4054/5054/6054 copier
  • Waliul
    • Jul 2010
    • 20
    [CQ] Interrup Copy function for Ricoh MP4054/5054/6054 copier
    Is there any one help me how can done "Interrupt Copy" on Ricoh MP4054/5054/6054 copier.
    Best regards.
    Waliul
  • freginold
    • Sep 2010
    • 102
    Re: Interrup Copy function for Ricoh MP4054/5054/6054 copier
    Best regards.
    Waliul
    Hello, there is an Interrupt key for that purpose. It's located on the upper right area of the operation panel, to the right of the Program key. If you have the smart panel installed (no hard keys) there should be an Interrupt soft button located on the Copy screen.
    Config page instructions for copiers, printers, & fax machines
    • sandmanmac
      • 3981
      Agreed. Just to summarize for the poster so there's no chance of confusion....PRESS THE BUTTON!
        • 37453
        I could be wrong, but to my knowledge, Interrupt will only work if you are making multiple copies of multiple originals. It will interrupt at the end of a set. If your are making multiple copies of 1 original or 1 copy of a multiple originals, it will not interrupt.
        • petermuylle
          • Jul 2015
          • 18
          The interupting will only begin after the job is completely scanned, so when Sorting is enabled and you scan from the exposureglass it will only start after you press '#'
