Ricoh Pro C900S - Error SC 900
  • MauroMM
    • Aug 2025
    Hello,
    We have issues with this printer Ricoh Pro c900S, in copy mode works totally fine, but when start sending jobs via fiery a alert is coming out "Funtional Problem Detected" sometimes is jut with that message, some other times comes with the code SC 900, since our company is located in the Caribbean, Ricoh technician are not easy to find, we have talked with a few but none seem to come out with a solution for the problem
    Any help or advice would be appreciated.
    Thank you
  • freginold
    • Sep 2010
    • 102
    Re: Ricoh Pro C900S - Error SC 900
    If it only happens when printing from the Fiery, it's probably either a problem with the Fiery or with the connection to the Fiery. Turn off both the copier and the Fiery (Fiery first) then boot them both back up. Make sure the Fiery shows "00" on its screen. Print a config page from both the machine and Fiery and make sure they both have good network connections.
    Config page instructions for copiers, printers, & fax machines
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      From the service manual: sc 900
      electric counter error
      Abnormal data in the counters
      Defective NVRAM
      Defective Controller
      check connection between NVram and controller
      Replace NVRAM
      Replace Controller
      UGLY BAD!!!!!!!!!!!!!!!!!!!!!!!
      I would reload the Fiery System before I did anything else..............
      Mystic Crystal Revelations
