NRG 2713z
  • j-ce
    NRG 2713z
    I really don't like working on this make/brand of copier and have never remembered how to enter the simulation mode on this copier. So if someone out there can please refresh my memory by telling me how to enter the sim mode and the sub code for running the sim for the developer on this copier. I really appriciate it, Thanks in advance.
  • djq2
    • Jun 2008
    • 25
    press the yellow reset key.. then107 using the copy keys.. hold down the red cancel button for a few seconds... sim 66 will run the dev...
    hope this helps
    • j-ce
      Thanks for your help but this is an old copier and the way to go into the sim is not like you do it to go into it like these newer models. I know that there are two ways to get into the sim mode...... one way is by pressing a button or something like that on the PWB on the back and the other is something similar to pressing 107 stop/clear but there is something missing in the beginning because you have to input something so that a little green dot in the display lights up and then you input the 107.... so if anyone can help me please do so I need to get this copier out of this small repair room....... Thanks in advance...
      • Lagonda
        • Aug 2008
        • 1649
        Do your self and the customer a favour, tell them its beyond economical repair. Its around 10 years old and there just any parts for it any longer. If you do manage to coax it in to life you will find that all the foam seals will have turned into chewing gum long ago and will leak dev and toner everywhere. Do the right thing and put it out of its misery! In fact do a bit of ethnic cleansing and rid the world of analogue copiers!!!!!!!!
