ricoh 2238
  • hodgiepodgie
    • 284
    ricoh 2238
    ok. got two 2238 copiers delivered.turned on copier everything works but the fax .tries to call out nothing goes out erro hang up or line fail.try to rx rings then hangs up after 8 or so rings error no answer or line fail. there is no dial tone.phone line is good all other faxes work.this happened with three 2238 in a row.sent one board back to guy we purcased them from he says fax board is good.did not work on any of our 2238's.got another board from a working machine that one worked in both 2238's.now can someone tell me what on gods green earth is going wrong.not our phone line.....
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    Make sure the line type is set correctly (tone/pulse), check that you have the phone line in the "LINE" jack and check the voltage one the phone line. If the standby and ring voltages are not high enough the fax will not pick up or dial out.
    • nmfaxman
      • 1702
      What error codes are you getting?
      You may just have to increase the attenuation.
      Does the machine work in the shop?
      • Paper_Jam
        Expecting a call.
        • Jun 2007
        • 101
        Make sure the phone line run is as short as possible and the phone cord is not coiled up. If the phone cord runs through a surge suppressor try bypassing it. You may also turn off ECM.
        • skinnypuppy
          CopierJanitor/Geargluer
          • May 2008
          • 92
          make sure there is there is no dsl (internet) running on the fax line. It is common for companies to share fax and dsl on the same line. If so put a dsl filter on the line connection cable
          • TonerMunkeh
            Professional Moron
            • 3865
            Also...
            Make sure you've got the correct type of fax cable, this has caught me out a few times, fax cables aren't interchangeable between machines!
            Hit it.
            • hodgiepodgie
              • 284
              2238 no tx rx
              found out problem.fax boards came from taiwan needed to change country code to 17.
