ricoh mp 3500:when copying a gray background, a double image.
  • ilyshaF
    • Jul 2015
    • 14
    Hello dear friends
    ricoh mp C3500 , there is no ready
    I went into the service menu and clicked 5801 memory clear, ricoh mp3500 entered the ready.
    now the problem
    opened the ACC test pattern, into a sheet of paper, offset colors black and cyan,magenta and yellow(001.jpg)
    When you copy a picture , a copy of the gray, color shift( a double image) (002.jpg)
    Need help configure the copier
  • Max
    • Oct 2011
    • 555
    Re: ricoh mp 3500:when copying a gray background, a double image.
    How are you getting a colour print out from a black and white copier?
    After resetting the copier to factory defaults you will need to put all the settings back. I hope you printed off all non defaults settings 1st. Second you will need to run a rough colour reg adjustment 1 st then fine after and that should fix your problem. Make sure the MUSIC sensors clean 1st. All in the manual.
    • TonerMunkeh
      Professional Moron
      • 3865
      The birth certificate for the machine will be under the jam removal decal in the front cover. You need to re-input the information on it.
      A memory all clear on a Ricoh colour machine should be an absolute last resort. It is not a common practice to fix faults.
      Hit it.
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        You need to run a Forced Line Adjustment after performing the Engine clear
        • wyo19
          • Nov 2012
          • 51
          just a note run "FORCED LINE ADJUSTMENT" "C" then "A" never do "B"
          • he7060
            • Jul 2015
            • 14
            Originally posted by ilyshaF
            Hello dear friends
            now the problem
            [ATTACH=CONFIG]30167[/ATTACH][ATTACH=CONFIG]30168[/ATTACH]
            Hello dear friends
            now the problem
            Run 2111 c and b.
            Sent from my SM-N910V using Tapatalk
              • 37393
              If you do not have the birth certificate or a non-default print out and forced line position fails, you are going to have to do manual adjustments until it is close enough for forced line position to work. There is a table in the trouble shooting guide portion of the service manual.
              • Iowatech
                Not a service manager
                • 3930
                As someone who had to do something like this due to my own goof up, this will probably take a while, too. But of you are patient and thoughtful it can be done.
                • bob marley
                  • Jan 2012
                  • 1339
                  don't do memory clear if u r not forced to
                  Live for yourself and you will live in vain. Live for others, and you will live again
                    • 37393
                    I have had to do a couple of 2238c in the past. Both times trade-ins that the boss wanted to sell. First time took forever. Then you figure out a process and it goes quickly.
                    • ilyshaF
                      • Jul 2015
                      • 14
                      Originally posted by he7060
                      Run 2111 c and b.
                      thanks for the help , it turned
                      in the Service Manual , written this for beginners
                      3.3.5 COLOR REGISTRATION
                      Line Position Adjustment
                      The automatic line position adjustment usually is done for a specified condition to get the
                      best color prints.
                      Do the following if color registration shifts:
                      􀂃 Do "Auto Color Registration" as follows to do the forced line position adjustment.
                      1. First do SP2-111-3.
                      2. Then do SP2-111-1.
