SCX-5935 1 inch blank trail edge
  • tnrtt
    • 156
    RADF, on the glass, printing. Has current firmware. Registration is fine Cleared memory and did NVM reset. Checked country, paper size,etc., everything I'd check on a setup. They didn't have legal or I would have seen if it did the same thing. Anybody ever seen this?
    • 23009
    Re: SCX-5935 1 inch blank trail edge
    That was my guess. B5 paper size, CUSTOM paper size, original size detection.
    Does it do it on internal reports? If yes, you can rule out the scanner/RDF. What paper size for each tray is displayed on the settings report?
    • arnh79
      • 468
      Are you using aftermarket toner? I've had this exact problem and it was caused by generic toner. I put genuine Samsung toner in and the problem cleared up, tried the generic stuff again and the problem came back. I've got 2 or 3 high volume 5935's that I can only use genuine toner in or the problem occurs. Funny thing is they don't all do it even if f/w and all other variables are the same.
      Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
        • 23009
        If you ever figure out an explanation of why, I'd like to hear it. =^..^=
        • tnrtt
          • 156
          Yes I AM using aftermarket cartridges. I have about 30 of these out there. This is the only one exhibiting that symptom. Thanks for the reply arnh79. I'll put an OEM cartridge in and post the results.
          • tnrtt
            • 156
            I'm with Blackcat. I'd like to know the reason for this if you can find out.
            • tnrtt
              • 156
              That was the ticket arnh79. Many thanks.
              • arnh79
                • 468
                Glad to hear it! Thanks for posting your results.
