Samsung M5370LX
  • luis1984bol
    • Nov 2011
    • 155
    [Error Code] Samsung M5370LX
    Hi:
    Recently one costumer machine report error code C3 1315 / C3 1316. Service manual says toner supply is abnormal and recommends to change the imaging unit (Drum), but it has only 8,000 copies.
    Does anyone had this issue?
    Thanks.
  • Victor679
    • Apr 2016
    • 26
    Re: Samsung M5370LX
    The problem could be that there is no toner being supplied to the imaging unit. Have you tried changing the imaging unit?? If yes then what i suggest is try to swap your toner supply motor; if there is no change then try to check the toner supply duct if its blocked.
    Hope this helps!!
    • luis1984bol
      • Nov 2011
      • 155
      Re: Samsung M5370LX
      Originally posted by Victor679
      Hope this helps!!
      I will change the imaging unit today and check if it works fine. Thank you very much!!
