CLX-9201
  • Berry87
    • Dec 2019
    • 3
    Re: CLX-9201
    I've resolved!!!For recovery HDD is necessary take open the first cassette and lateral panel, push the wake up buttom when the printer is starter, and the printer acept the recovery file!
    The printer is like new!
    • mrfrenzy
      • Nov 2019
      • 3
      Re: CLX-9201
      Hello Berry!
      Which model hard drive did you use?
      Regards
      Pierre
      • Berry87
        • Dec 2019
        • 3
        Re: CLX-9201
        Original Toshiba 320 GB, after recovery the HDD is back to work!
        • kangio
          #19
          Re: CLX-9201
          Hi Berry ! So can you guide me through this ? I don't know where the request file is ?
          Hello Berry, Currently I do not know where the request file is? So can you guide me through this?
          • ChrisW_86
            #20
            Re: CLX-9201
            I have the same problem, can someone send me the scripts by e-mail to admin@chrisw.pl? Thanks in advance
            • Crz
              • Feb 2021
              • 2
              #21
              Re: CLX-9201
              i have the same problem - my hdd seems broken.
              For the new HDD i need the Unix scripts - could anyone send them to me please?
              christian@immels.de
              Thanks in advance!
              Chris
              • cvcr
                • Feb 2021
                • 2
                #22
                Re: CLX-9201
                Can someone send me the scripts by e-mail to adrian@validaricleanrooms.ro? Thanks in advance
                • gnas74
                  #23
                  Re: CLX-9201
                  Hello everyone, I also have the same problem...
                  Can someone send me the scripts by pm or email: 74gnas@libero.it?
                  Thanks in advance!
                  Dav
                  • SandyGoh
                    • Apr 2021
                    • 3
                    #24
                    Re: CLX-9201
                    hello everyone, i am having the same issue with the copier. I have just changed the HD as the previous HD died. anyone has anyadvice what i should do with the new HD? I am able to go to the server but not sure which files to download. and what i should do with the new harddisk, anyone can point to me the files to download and what to do next please.. much appreciated.
                    • aristos87
                      • Oct 2021
                      • 12
                      #25
                      Re: CLX-9201
                      Anyone having the recovery image? hds and ehd from the ftp won't work with usblist2.exe
                      • alexanderdia
                        • Sep 2015
                        • 6
                        #26
                        Re: CLX-9201
                        I have the same problem. Can someone send me the HDD image file and the script to sport_kille37@hotmail.com
                        • aristos87
                          • Oct 2021
                          • 12
                          #27
                          Re: CLX-9201
                          If your UI is stuck and the printer is working just take the that UI firmware and put it on a usb after you pressed the * 0 # and let it there, eventually it will update the firmware of the touch panel. The file done the job was V5.16.00.33.00_2015022623.hd and I uploaded it here:
                          UI Recovery V5.16.00.33.00_2015022623.hd - Google Drive
                          If you want the hard disc recovery you can find it here:
                          System Recovery CLX_9301_9201_EV11.11.14.09_FS11.01.00.00.71.ehd - Google Drive
                          Recovery for the hard drive I never tried so far as in my case only the display firmware got corrupted. For sure you will find instructions in this forum if you search for clx-9201
                          • alexanderdia
                            • Sep 2015
                            • 6
                            #28
                            Re: CLX-9201
                            Big thanks aristos87!
                            Do you also have for Samsung Multixpress SL-X4300LX?
                            • aristos87
                              • Oct 2021
                              • 12
                              #29
                              Re: CLX-9201
                              No, those I have as I was searching to fix my own printer. I am not a technician or so.
                              There is an hp ftp server with all the recoveries. You need to check there using filezilla or so:
                              ftp://ftp.hp.com/pub/softlib/software13/printers/ss
                              • alexanderdia
                                • Sep 2015
                                • 6
                                #30
                                Re: CLX-9201
                                I tried with Filezilla ftp.hp.com but I get an error message "offline from server" or something like that. Alright big thanks again for the 9201/9301 Samsung
