Samsung clx6250. Blank areas and black spots
  • DOE
    • Mar 2010
    • 258
    Samsung 6250 that sat for a month and getting blank areas and black spots. Black copies are worse than color. The first copies I made look decent and then the more I made the worse it got. Does Black drum unit need replaced possibly. Copies were ok a month ago.
    Re: Samsung clx6250. Blank areas and black spots
    kinda hard to tell if we don't have more info..
    how many pages total..
    how many on supplies....
    AW Fuck it getting tired of asking the same old fucking questions that should be supplied by the OP.
      • 22929
      Oh ... maybe an image sample might be pertinent? =^..^=
      • copydocinc
        • Mar 2015
        • 263
        A new black toner cartridge will likely fix it. Be aware there are a lot of bad refilled/compatible toner cartridges out there, so if you replace it with another compatible, it may also have issues similar to the one in the machine right now.
