Hello - I have a Samsung MultiXpress SLX-3280NR that never boots past the Samsung Logo on the touch panel screen. When I turn it on it never gets past displaying the "Samsung" logo.
I would like to correct this and restore the printer back to full functionality - if anyone has any insight upon reading through my post please let me know your thoughts!
When I toggle ON the power switch for the printer it goes through the initial boot sequence but the display screen always hangs and stays on the "SAMSUNG" logo and never gets past this point.
Before I turn the printer ON I can press and hold either combination of keys #1 or #2 shown below to get to the touch panel calibration screen. After I go through the full touch panel calibration successfully the screen stays BLANK and I cannot do anything further so I end up turning off the printer at that point. I can turn the printer back on but it gets stuck at the Samsung logo again.
#1 key combination = the zero "0" key by itself
#2 key combination = the *, 0, # keys together
I have been able to access the syncthrough web management portal and I've been able to login to the printer and could print pages from a network connected computer successfully.
Just lately in my recent troubleshooting I can no longer access syncthrough web portal... the Orange LED on the Ethernet port of the printer is illuminated but the Green LED is not so it seems like data is only going one way now.
From some research I have done it seems likely that one of the following is the problem:
- HDD failed
- OPE board faulty (this is the touch panel unit that contains the LCD screen, OPE circuit board behind the LCD and the operator keypad)
I have tried replacing the original Toshiba 320 GB HDD with an older Western Digital 320 GB HDD. The replacement HDD did not resolve the problem of the hanging Samsung logo upon startup. The printer does recognize when there is no HDD present so it is "sensing" the HDD hard drive properly.
I have also tried replacing the full touch panel (OPE board I believe is what this is called?). Upon replacement I performed a touch panel calibration which was successful but the screen stayed BLANK at the end of the calibration and I had to perform a hard reset by turning the power switch OFF/ON. When the printer started back up the hanging Samsung logo was still there.
I am currently running the latest firmware version that is available from the HP support site (website link is below) - firmware version V3.00.17.00
I have not been successful in re-loading the firmware from a USB stick inserted into the printer (I might not be following the right steps for this USB-stick firmware re-flashing) however using the syncthrough web access I have been able to try and re-load the same version of firmware (V3.00.17.00) however this never seemed to resolve the hanging Samsung Logo issue.
Can anyone think of anything else that I should check? Please help me get rid of this "hanging" Samsung logo and get back the full functionality of this printer.
Would it be beneficial to try an older version of firmware? I do not have any other firmware versions - only the latest V3.00.17.00 so I have not been able to try and roll back the firmware to an earlier version to see if that solves the issue of the hanging Samsung logo upon startup.
Thanks for reading! I look forward to some help with this if anyone has suggestions - I am out of ideas myself...
- HDD failed
