Samsung CLX-3175 Drum Reset
  • Thebmwteam1
    #16
    Re: Samsung CLX-3175 Drum Reset
    how can you fill in the # and nummber? when i press on menu on my CLX-3715 i have only two possible choses to chose of?..
      • 23009
      #17
      I don't think I could make this any clearer.
      If you have a CLX-3175 without number buttons, I don't know how to do it. =^..^=
      • roby_eng
        #18
        This solution worked for me. It's taken from the following link:
        I have a samsung clx-3175 printer telling me to replace the - FixYa
        Log into the service menu Samsung CLX-3175 without a numeric keypad similar to the unit Samsung SCX-4623F/FN:
        Consistent set of combinations of "MENU" - "ID COPY " - "LEFT" - "RIGHT" - "MENU" - "BACK"
        The unit switches to English, if you installed any other.
        In the menu appears TECH MODE.
        To enter the reset require a password1934. The numbers by pressing "LEFT" - "RIGHT",
        After each number press the "OK"
        Good luck in the reset.
        • roby_eng
          #19
          I already reset the counters in the Samsung CLX-3175 printer (without fax) (read my previous post for How to..?).
          I tried to print a test page, the print is so good, but I have lines of colors on the printed page (Yellow, Magenta, Cyan, and Black respectively). These lines appear twice on the page, up and down.
          What's the problem???????????
            • 23009
            #20
            Can you scan a sample? =^..^=
            • roby_eng
              #21
              First printed page is (1) that's with picture. After multiple printing, the two sets of lines were moving downward. The lower set was removed and the upper one is still there, as you see in (2). 1.jpg 2.jpg
                • 23009
                #22
                Does the pattern re-occur at 187mm intervals? There is probably a scratch on your new drum. Each time the scratch goes by the drum cleaning blade it causes the drum drive to hesitate, creating a line each time a color is developed. The lines will be spaced 0.5mm apart.
                Yes I'm sure. =^..^=
                • composee
                  • Oct 2012
                  • 24
                  #23
                  you can use hardware drum reset with 56ohms fusible resistor like as original new drum unit.
                  • Seb
                    #24
                    [/QUOTE]
                    • RichardT
                      #25
                      Hi I'm a new user and would appreciate any opinion you can give. I have installed a new drum unit on a Samsung 3175FN, got the "Install Imaging Unit" error message and followed the instructions above.
                      I get the "Clearing..." message for a second or so, go back but it still isn't clearing the error message. I'd be very grateful for any further ideas.
                      RichardT
                      • Seb
                        #26
                        Hello Richard,
                        What does your control panel look like? I have a Samsung CLX-3175N and it does not have a numeric keypad. The solution I found to reset the count on my machine was:
                        This tip was posted by, I think, roby_eng last May 27th. It might be too late now that you have installed the new drum, but, just so you know, when I did my researches, I found out that the ''replace imaging unit'' message appears after a certain number of prints, but does not necessarily mean that it is no longer operational. I reseted the count without changing my imaging unit and the printer still works fine (knock on wood). Allowed me to safe a few bucks.
                        I hope this helps. Let me know the outcome.
                        Take care,
                        Seb
                        __________________________________________________ __________________________________________________ _______________________________
                        RichardT
                        • amb
                          #27
                          Hi Black Cat
                          I was reading your thread after Google information related to Drum reset for Samsung color printer CLX-3175. But information about reset would only apply for CLX-3175FN model. How can we rest a drum on the brand printer with model number CLX-3175 who don't have numeric keypad to reset/apply this option. Can you let me know if you also have this solutions.
                          I have Samsung model CLX-3175 (standard printer) with out numeric keypad and want to reset its drum error. Your prompt reply will be appreciated because not able to use printer.
                          Thx.
                          KBA
                          • Megato
                            • Sep 2009
                            • 13
                            #28
                            Re: Samsung CLX-3175 continu job without stop
                            I HAVE Samsung CLX-3175 continue job without stop WHEN I PRESS 1 COPY IT WORK CONTINUE WITHOUT STOP I AM REST IT BUT NO NEW
                            CAN YOU HELP ME
                            • JustManuals
                              • Jan 2006
                              • 9838
                              #29
                              Paul@justmanuals.com
                              • danleaf
                                #30
                                Re: Samsung CLX-3175 Drum Reset [CLX-3305FW image unit CLT-R405]
                                I have tried to do this.. and follow these instruction.. for my CLX-3305FW the image unit code is CLT-R405
                                Press: Menu, #1934#, Menu, "Tech Mode <Tech Mode>" OK, "Data Setup" OK, > x7 to "Clear Counts" OK, "Enter Password [????]", 1934, OK, "Clear Counts [Total Page CNT]", >x3 to "[Imaging Unit FUSER
                                But this does not clear the replace image unit error. I switch off the printer and still get the same error.
                                can anyone help, or do i need to do that 56ohm fused resistor thing as i can find on YouTube.
                                Leaf
