samsung CLX2160
  • Tze Chian
    • Feb 2013
    • 36
    [Misc] samsung CLX2160
    Output margin go up. What is the part cause it like tat?
    Thank you very~~ much~
  • JustManuals
    • Jan 2006
    • 9838
    Re: samsung CLX2160
    Paul@justmanuals.com
      • 23009
      Re: samsung CLX2160
      It's probably simpler than you think.
      Samsung's have very loose jam timing. That is to say that the paper can feed 25mm late or more, and not detect a paper jam. So treat this as if it is jam condition from the feed tray and apply the typical resolutions: dirty tires?, worn rollers? worn clutches? ... in that order. =^..^=
      • Tze Chian
        • Feb 2013
        • 36
        Thx very much blackcat~ but rollers,tires and clutches all look fine..
          • 23009
          Re: samsung CLX2160
          OK ... what do we do next if they look fine but still don't work? =^..^=
          • Tze Chian
            • Feb 2013
            • 36
            Say goodbye to the machine~^^ No idea...
            • Blizzoo
              • Aug 2013
              • 608
              Re: samsung CLX2160
              If you print a job with more pages how are the printouts?
                • 23009
                Re: samsung CLX2160
                Just because the parts look good, doesn't mean they're in working condition. Replace the rollers first. =^..^=
