CLP 315 Black spots on the back page
  • geotzia
    Hello maybe you can help me with my laser printer Samsung CLP 315 ,makes at the back of the page black spots (black-brown) seem like toner,and if you scratch them you can remove them... I just open the machine and clean the drum the cartridge and i think everything with vacuum cleaner- but the problem is still there so if i print both sides i have the spots at both sides too.....
    Thanks in advance
    • 23009
    Re: CLP 315 Black spots on the back page
    Since the color of the toner you're seeing is brown, most likely it's a primary transfer belt cleaning problem.
    It could be something as simple as an address label stuck to the primary belt, or as catastrophic as a ripped belt. Whatever you discover, you'll probably need to replace the primary transfer belt assy, that only costs a little more than the whole printer when you bought it. =^..^=
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
