Samsung photocopier print test paper continously
  • KIMBACHE
    [Misc] Samsung photocopier print test paper continously
    Dear,
    I have multipurpose photocopier SAMSUNG SCX 6320F, which print paper whenever you switch it on.
    The problem started when i installed driver for the said photocopier, which prompted me to print test paper.
    Its unfortunate the photocopier prints many paper with no known word but only letters instead of test page.
    It only stops when you switch the photocopier off.
    Any ideas please to sort it out.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: Samsung photocopier print test paper continously
    Originally posted by KIMBACHE
    Dear,
    Sounds like you loaded the wrong print driver.
      • 23009
      Does it stop printing when you pull the network connection and re-boot? You may have a document stuck in the print queue, reprinting again and again. =^..^=
      • KIMBACHE
        There is no paper stuck in and nothing stop the photocopier from printing unless you switch the printer off, sometimes even if you cancel the job it keep in printing.
        Not sure of the driver let me uninstall and see
        Thanks for your response anyway.
