Sharp AR-M257 setting own name on Fax Header for outbound transmissions
  • FutureDigital
    • Aug 2015
    • 7
    [Misc] Sharp AR-M257 setting own name on Fax Header for outbound transmissions
    Hello all,
    I have a client who has a Sharp AR-m257 that has an incorrect name when sending faxes on the header of the page.
    They are a medical office and for insurance purposes they need that to be changed.
    I attempted to access the device's GUI, but I saw no option for "Own name" or "Fax Header" or anything similar to that
    I have some newer Sharps here in the office where I am able to register my own name through the system settings, but I am unable to find any guide showing me how to do it on this older machine
    Does anyone know how to do this? Any help I would greatly appreciate!
  • mttech
    • Mar 2014
    • 127
    Re: Sharp AR-M257 setting own name on Fax Header for outbound transmissions
    Try this. Touch custom settings, then login as the key operator. Touch fax settings, then default settings. You should find it there.
    • FutureDigital
      • Aug 2015
      • 7
      Thats really helpful, thank you.
      I'm honestly not too familiar with Key Operator login info, from what I've read in a search is that it is a number that is set up and must be remembered like a pass code, and that is is defaulted to five 0s.
      If the machine was previously working with different headers, I would assume the default Key Operator # had to have been changed. If this is the case is there an easy way to reset it and retain the rest of the customer's settings?
      • ZOOTECH
        Senior member of CRS
        • 3375
        TC 22-7 will give the current Key Operator number.
        • FutureDigital
          • Aug 2015
          • 7
          I'm also not sure what to make of this.
            • 22996
            I would like to introduce you to the service manual. It tells you how to operate the service modes. All it requires is reading skills, and the willingness to read.
            Buy a manual. Read it. =^..^=
            • FutureDigital
              • Aug 2015
              • 7
              • FutureDigital
                • Aug 2015
                • 7
                I get your mindset here, but let me be clear in that I searched for the meaning before wandering back in here for help. Trust me, I don't want anyone to hold my hand. I was not able to get the information needed through my search. I'm willing to do it again, but it seemed like I was missing something
                Nice schtick
                  • 22996
                  Sorry Sir. After a while you may discover that you, too, are dis-inclined to read manuals for those that unwilling to do it for themselves. =^..^=
                  • FutureDigital
                    • Aug 2015
                    • 7
                    I understand. I'm going through the manual and I believe I found what was mentioned as TC 22-7 and learning what that means
                    • Akitu
                      Legendary Frost Spec Tech
                      • Oct 2010
                      • 2595
                      For the sake of ease, you may want to try reading the operator's manual instead of the service manual. That one will give you the full read-through on all those end-user features you're searching for. The service manual gives the technical details of the machine and not so much the operation side.
