my copy
Re: my copy
Can anybody read that text box? I sure can't.
You might also throw in what model number you're working on, for those of that aren't psychic. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
Re: my copy
F1-87 is almost always a lift motor issue for the finisher output trays. We usually see this happen when someone has set something next to or under the tray or they got bumped and the tray isn't lined up correctly. It can sometimes be cleared by restarting the machine or using sim 14. If not, you need to make sure the motors and sensors are functioning correctly.Comment
Re: my copy
Shift Jogger Motor Trouble
Motor lock, motor harness short/open, control PWB trouble, home posistion sensor trouble, connection harness/connector connection trouble.
Use Sim. 3-3 to check the operation of the shift jogger motor.
Check connection from control pwb to the motor. replace the control PWB and the snsor part.Comment
