AR455 Washed Copies
  • ntbann
    • Jan 2012
    • 631
    AR455 Washed Copies
    I have this machine that is giving light copies. Call was for this issue so I did a full pm. this didn't help. Leaning toward HV PWB. Just wondering what everyone else thinks. Thanks.
    Scanned image from MX-M503N_donotreply@kerralbert.com_20150812_134908.pdf
  • Jan
    • Dec 2014
    • 15
    Re: AR455 Washed Copies
    Did you check the drum earth contact ?
    transfer roller contact's ?
    check the image on the drum (maka a copy and open the front cover so the paper is jammed by the reg, )
    if the image is good chech the transfer roller
    Jan
      • 23010
      Does it affect side 1 images and side 2 images when duplexing? The only record I have even close to the 33mm intervals you are seeing is a developing roller problem:
      Light areas along the front of the original/copy, within 30mm of the front edge of the copy, print or facsimile reception, at 27mm intervals. Uneven floor, 10mm lower at the rear, causing poor coverage of the mag roller at the front. The effect is seen best in simulation 64-1, test pattern 64, as a "Z" shaped void at 27mm intervals. Level the copier & finisher with the casters.
      Take a close look at your developer brush. I think you'll find your pattern there. =^..^=
      • tr210907
        • Jul 2011
        • 40
        Do not want to insult intelligence but for the pm 455nd was dev used right.. Only saying because I had new tech call me other day with samples similitude to your example and after going through list of questions found out he used MX b20nv instead of mx b42nv
        • Jan
          • Dec 2014
          • 15
          Also check the MG roller, proberly broken on the rear side, the axel is turning free in the roller.
          Jan
          • ntbann
            • Jan 2012
            • 631
            Thanks for replying. The DV unit was the culprit. Mag roller would turn by hand but when inserted in machine it was slipping.
